Canton LE-600
Bratwurst7s
In The Frying Pan
I was cruising the 'bay and came across a pair of Canton LE-600 speakers, only a minute to go before the auction closed. On a whim (and because the price was right) I bid and got them for €21. LOL after buying them I found that they were one of the earliest speakers that Canton produced, and the top of the series at that time. 1973-1975 1st edition, 1975-1978 2nd edition.
They have replacement non-oem tweeters and are missing the grills, and have some dents and scratches. Nonetheless I think that they are worth saving. I'm looking for some original tweeters. Anecdotal evidence suggests that Canton PN 2219 is the correct item, a 19mm soft dome (in other words someone on the web says so). The cabs are painted black, possibly original, but there is real wood under there. I'm contemplating trying to strip the paint and refinish them in oil and wax.
I did hook them up yesterday and all drivers make sound, but haven't gotten any further yet except for writing Canton to ask if the tweeter PN that I heard about is correct, and for any other info that that they would be willing to share. Pictures to follow.
Cheers,
James
So I finally got some other stuff out of the way and had time to take a few pics. DSC01973.jpg DSC01974.jpg DSC01975.jpg DSC01977.jpg DSC01979.jpg DSC01980.jpg
Serial numbers are 640801 & 640816, so very close to each other production wise. Hifi Wiki shows the following info concerning the LE 600:
Size:
  • 495 x 275 x 220 mm (HxWxD), Volume 29,9 Liters (first Series)
  • 495 x 275 x 240 mm (HxWxD), Volume 32,7 Liters (second Series)
  • Drivers:
    • Woofer: 1x 250mm (Nr. 2653) / 235mm (first / second Series)
    • Midrange: 1x 38mm (Nr. 2540)(2760) / 30 mm soft dome (first / second Series)
    • Tweeter: 1x 19 mm soft dome (?2219?/??)
  • Load (RMS-/Peak): 60 / 80 Watt (first Series), 70 / 100 Watt (second Series)
  • Frequency Range: 22 - 25.000 Hz, (21 - 25.000 Hz, second Series)
  • Crossover Points: 900 / 4.500 Hz (first Series), 680(750?) / 2.700(2.800?) Hz (second Series)
Going by the box measurements I have 2nd series models. Nice that someone has provided part numbers for the mids but I wish that they also showed the PN for the tweeters.
Cheers,
James
As I said earlier, I read on the 'bay that people were selling 2219 tweeters ar originals for these boxes and I bought a pair foe €25. Unfortunately they turn out to have a different mounting hole spacing than the studs in the box 60x95mm (2219) vs 60x80mm (box). So I still need to find some tweeters. No big deal, I have lots o time and the tweeters that I bought will just go on the shelf for a future project.
I won't have time to open up the cabs or do anything with them for a few weeks at least, to many other projects going on right now. The last owner lost the grills somehow and had glued some kind of foam to the front at some time. He removed the foam before selling them but the baffles need some serious cleaning up. I need to decide if I'm going to attempt to strip the black paint. The veneer seems to be pretty thick but I've never done any paint stripping before and am concerned about doing something that would cause the veneer to separate from the cabs. But it would be nice to get them to a natural wood finish. These old Cantons look really beautiful in natural oiled finish. And of course I need to find some grills.
The previous owner did a crap job of installing the replacement tweeters, actually drove screws right through the cabs with the ends sticking out of the front baffle. All of that will have to go and be cleaned up.
DSC01982.jpg DSC01984.jpg DSC01985.jpg DSC01988.jpg DSC01989.jpg DSC01993.jpg DSC01994.jpg
Cheers,
James
So. LOL, it's only taken me 3-1/2 years to finally get a round tuit and get started on restoring these speakers. Better late than never.
For the first step they got disassembled and I used the orbital sander to just get the major amount of the black paint off of the cabinets, as well as most of the layers of glue and foam residue from the front baffles. The tweeter cutouts have been cleaned up and the screw holes filled with wood putty.
Underneath the black is still the original clear-coat. Now I have started painstakingly hand sanding until I just start to reach the veneer.
Cheers,
James
The second cabinet is now sanded and cleaned up with acetone. This cab was in much worse shape than the 1st, with a lot of scratches. In this case the top was actually more scratched up than the bottom. Still, it cleaned up pretty good all things considered...
And the brown closed cell foam that I ordered arrived and got marked for cutting new seals for the rear plate.
Cheers,
James
Sweet!!!, nice job!!!!
Thanks! They will get painted/oilwaxed this week. I hope. That's kind of weather dependent because I need to do them indoors but still need some ventilation, and it's turned cold and rainy here.
Cheers,
James
Going to be worth thework. Look great.
Thanks!
While I'm waiting for a little bit warmer temps I put the crossovers on the bench today.
There are only 2 elcos in the crossovers, #2801 = 47µF and #2571 = 80µF. I replaced them with a Mundorf 47µF and a Jantzen 82µF. After that all of the other connections were re-soldered.
All of the other caps are MKT film, 8.2µF, 10µF and 16µF.
Cheers,
James
Those are some lucky Cantons. What a save!
Hi Jon!
Workin' on it. Things should really start to come together in the next week. I expect that they will be some pretty decent sounding speakers when finished.
Speaking of which, iirc you have some Braun or ADS L-710's? A couple of weeks ago I acquired some distant cousins of those beauty's, the Braun LV-720 active speaker. After I finish with these L-600's I'll be starting a thread on the 720's. I should be starting on the Speakerlab S7WA's that are lurking on my cellar but I just can't resist working on the 720's. Stay tuned...
Cheers,
James
Will definitely tune into the Bratwurst7s channel for that! Can't wait to see the amplifier section of those 720s.
Would make a such a simple, clean system: Nice preamp and the LV-720s.
So, the weather here finally cooperated and got nice on Friday. I took advantage and got both speaker baffles sprayed black. The paint was supposed to be semi-gloss but turned out to be more of a full gloss, but OK. It still looks much better than what I started with. Saturday I got the first coat of Osmo Hardwax-Oil on the veneer, and yesterday the second. imho they turned out reasonably good.
Cheers,
James
Agree, I think that with a decent pre-amp they should sound pretty good. And I have a Yamaha CX-600 pre that is finally almost finished to use with them.
Cheers,
James
Now I can finally start to put these speakers back together.
The midrange drivers. PN 2760 is what was installed. They have a symmetrical 80x80mm mounting hole pattern and measured 4.1 ohms DCR. The original mounting seals for the mids and tweeters cleaned up nicely so are being re-used.
Cheers,
James
James, are these the predecessors to Canton Karats?
No. The LE series is afaik one of the very first series that Canton introduced, if not the first. Info that far back is very hard to come by. There were/are other later LE series also.
1978-'79 they brought in the (first) GLE series (40, 50, 60, 70, 100). This was replaced with the Quinto series, 1980-'85, (510, 520, 530 and 540)(although later there was also a second GLE series). The Quinto is the direct predecessor to the Karat, which started in 1986 with the 100, 200 & 300 models.
That's my best take on that part of their history.
Cheers,
James
