Hi James - i got the speakers apart. Electro caps look a little different. Take a look.
The larger has print Wego, 25 VAC, Mat, Nr2571 10H, ALR/U, bipolar
smaller one Wego, 25 VAC, Mat. Nr. 2801/9H, ALR/U, bipolar
I swapped the capacitors for the same ones you put in before i realized my originals were different. Not much change in sound. Maybe slightly less power than the speaker I did not swap the caps.
Did I do something stupid? I am new to this.
Thanks again for your help.
Best
Chris
I forgot to mention, if you haven't done it already I would without a single doubt re-solder all of the connections.
Not touch up with a bit on new solder but de-solder, clean off the old flux with acetone and re-solder fresh.
Every. Single. Connection.
Cheers,
James
