hmap
Thanks!
Added to the list.
James
this topic helped me more when i needed it - so,thank You man!
Thanks!
Added to the list.
James
just took a look at the list -i would say You have made a mistake - please check!Thanks!
Added to the list.
James
There are 121 items listed in the first post, and 262 posts so far in the thread.just took a look at the list -i would say You have made a mistake - please check!
,There are 121 items listed in the first post, and 262 posts so far in the thread.
It would be helpful if you told me exactly what you are making reference to.
Please note that I do not have a perfect memory and do not spend all of my time in this thread. I am happy to make corrections but you have to wok with me a bit.
James
Hallo zusammen, ich bin hier neu und erstmal Gude.
Habe ein canton sc combi set und möchte es erneuern, auf der weichen vom Subwoofer ist die spule mit der 5872 konnte aber nichts finden.
Vielleicht hat einer von euch den Wert, wäre sehr dankbar.
Beste Grüße aus Deutschland/Wiesbaden
somebody made a mistake somewhere - there should not be two capacitor values under same code. these days i should refresh my GL310 with new capacitors so I will have a better look at it,I will report whatever i find out.Canton Karat 300 crossover :
The 2102 Capacitor is 6.8 uF
Regards
Gabor Laczko
Hungary
Thak you so much all for your work in collecting "gold" information!!!!
