MathiasBerg
Hi, Laczko Gabor.Hi MathiasBerg!
The Jantzen Elecap is an electrolit capacitor, so it is not a film capacitor ! ! !
I didn't say it was film. I say i mounted the Jantzen Elecap.
As I can hear, my speakers sounds great again.
Mine doesn't have that. Definitely looks like a protection circuit to me.View attachment 2986505
Opened up my Ergo passiv this day.
There seems to be a extra board on the crossover.
Anybody seen this before?
I think it's a protection circuit?
The circuit board looks similar to the one that was also temporarily used in the ct1000. Unfortunately, I lack a schematic for it, otherwise I could write more about it. But I suspect a protection circuit for the tweeter.Mine doesn't have that. Definitely looks like a protection circuit to me.
Also, my Ergo Passiv crossover only has 4 caps and 2 resistors (see post #210).
Did canton use same crossovers for different speakers?The circuit board looks similar to the one that was also temporarily used in the ct1000. Unfortunately, I lack a schematic for it, otherwise I could write more about it. But I suspect a protection circuit for the tweeter.
In my opinion canton changed some crossovers every 12 months. This little circuit was obviously used in several crossovers. Some coils and capacitors were surely used in several crossoovers, too. But I did not remember canton using the same crossover for seceral speakers.Did canton use same crossovers for different speakers?
2606 and 2639 are 2 that I don't have in the list. What are the voltage specs on those ones please, then I will add them to the list.Hi Guys!
My new project is a Canton LE 500 crossover recap.
Electrolitic caps:
2103 - 10 uF
2606 - 22 uF
2424 - 33 uF
2639 - 100 uF
Resistors:
1 ohm
10 ohm
27 ohm
I will often replace the square block ceramic wire wound resistors with 10w Mills or Ohmite Gold non-inductive wirewound types.Hi Guys,
If you replace all the electrolytic capacitors, you can also replace the resistors. This is not necessary. I already had a really burnt crossover from a ct90, but the resistors on it still worked. But something like that looks unattractive.
Thanks
Hi James!2606 and 2639 are 2 that I don't have in the list. What are the voltage specs on those ones please, then I will add them to the list.
Thanks,
James
The others2606 and 2639 are 2 that I don't have in the list. What are the voltage specs on those ones please, then I will add them to the list.
Thanks,
James
