MathiasBerg
Does anyone know the correct values of the coils 5879 and 2036?
The 2036 smells slightly burned.
The caps measure correct.
from audiokarma: 5879 --> Drossel KD FK 52-440-1,04,27- 4,53mH
maybe the same error: (?)
http://www.hifi-forum.de/viewthread-225-2931.html
I would also have suggested measuring the working choke in the other speaker. FK chokes have less ohmic resistance. If you have the impedance value of L2036 and then know the DC resistance as well, you can see if an air core coil can be used without much change. In the other case, you can certainly buy FK chokes new or used.
Where did you find the 100uf cap? It is film, right?Update
I bought two new coils and two new 100uf caps.
The 2036 is now replaced with a Jantzen 30mH 1,2ohm ferritecoil. A very very short test listening and it works and sound good. I will listen properly within a few days. I had to rebuild the board littlebit as the new coil is very heavy and do not have the mounting hole…
View attachment 2762121 View attachment 2762122 View attachment 2762123 View attachment 2762124 View attachment 2762125 View attachment 2762126 View attachment 2762127
I bought them at Hifikit in Stockholm (exellent service!)
Film: I dont know?
I think it is this ones:
http://www.jantzen-audio.com/wp-content/uploads/eleCap-5-Data.pdf
