capacitor nichicon kg amplifier nad
mshari
Hi, can Snap-in Nichicon KG capacitors be used instead of a radial- capacitor and wired into the holes?
In the pre-amp section 2200uf 50v
Where in the preamp section is this cap? If it's actually in the preamp section, it could be the 2200uF cap that is part of the RIAA filtering circuit. If so, then a 50V snap-in cap would be overkill.
A picture of the schematic would help.
Hi
Look, these are the two large capacitors, their actual value 2200uf 50v
preamp
HI
It has been upgraded—far better than the factory version. Even the original Chinese capacitors had a pleasant sound signature.
However, the bass has become even more pronounced after the upgrade; I’ve been trying to fine-tune it for two years now. I suspect the speakers themselves might be the issue—they likely require a larger room—but it still sounds beautiful.
Capacitors used:
Nichicon FG for the power supply;
audio note power suplay pre amp 220uf
Nichicon Bipolar ES for the signal path and feedback;
Elna Silmic for the signal path;
Mundorf for the main filter (large capacitors);
Elna Cerafine for decoupling 2 47uf
Elna Cerafine dc Before bias adjustment 2 47uf
Jantzen 0.47 film
I’m just curious to experiment with "audio-grade" capacitors to see if they actually make a difference, or if it’s all just in my head.
