I like the pillbox idea, if only because it's kind of humorous! Is that large enough to hold the headshells as well?.
Very Clever with the headphone idea!
I use the SHURE holder and it is not ideal, as the headshells "hit each other" when you shut the case if they're particularly long headshells.
I bought another one, http://www.amazon.com/Odyssey-KCC-4-Cartridge-Black-KCC4PROBL/dp/B004I45S42
the build quality is awful, the slots are too tight for the headshells, and the headshell mounts are very crappily fixed to the bottom of the case, and are about to come apart!
Wow! Thanks for mentioning this. I was going to order one of these:http://www.amazon.com/Odyssey-KCC2PR2SL-Turntable-Cartridge/dp/B008MW90VI/ref=wl_it_dp_o_pC_S_nC?ie=UTF8&colid=6K040Y0Z81VE&coliid=I3SBPHGXKHWDCZ
Now I'm having second thoughts.
I like the Plano idea, but I'm a little concerned about carts without stylus protectors being stored with that.
Yeah, true, Plano seems economical, but potentially risky. If you store the cart on a headshell and put it upside down (stylus up), it may be okay unless you drop/shake the box. The Shure one (DIY aside) seems the best if the headshells don't touch each other.
