Julian12345
Hey @gadget73 , I bought all the stuff to build a dummy load with 4x 100 watt resistors so will do that today. I missed your question re original transistors and yes I did actually populate one channel with new old stock originals and performed no different so I put the modern subs back in figuring its better to abuse available stock over rare originals. I have maybe 8x 708 and 4 of the other one so in the end I could swap them back in once sorted
If say, there's just no reading on idle current perceptible and adjusting idle pots does nothing then is it possible something between the driver board and the mess of wiring on the chassis/output trans area is wrong?
Is it possible driver transistors would generate lots of heat if something was restricting the flow of juices to the output?
I'll get to the dummy load /scope now. I might take a few days to generate new info, work is busy this week and I might have to prioritise day job
Thanks for your help so far. It's helping me gather a way of thinking, processing, in a problem solving way
