Thanks !!!! You have any experience with old prologic 1 amps ??Dupe post deleted per member request.
Nah - I'm running a 2009 Integra DTC 9.8 - I don't bother with HT electronics older than that.Thanks !!!! You have any experience with old prologic 1 amps ??
so i wont lose any sound not using them??@ultumax I've already told you about Dolby Pro-logic in my previous posts. If you can't have the (limited) monophonic rear channel coming out of a speaker at the rear like it should, then just remove the rear speaker(s) completely. Don't wire additional connections to other channels, you'll create unwanted effects doing that. If you are not using the rear channel as it was intended to be used, don't use it at all. Concentrate on having a good centre and front left / right setup and you will be much happier with it.
Most of us posting here are trying to help you but you do make it hard because of your constant asking of the same questions and not listening to or acting upon many of the good suggestions and advice you have been given.
so how dos prologic work-noView attachment 1622067 surrounds?
What can I use as a doorstop ? So door does not hit my receiver ?
Wow nice yeah big sound !!!!When you get a job;![]()
@Markoneswift
Don't waste your time, he probably doesn't even remember what questions he's asking as he's posting between multiple threads, asking all different types of questions, sometimes twice in a row albeit a few minutes apart, while constantly going off topic.
For example
Obviously I don’t understand Dolby prologic or why the surrounds don’t do much at all .@Markoneswift
For example
That, plus you probably aren't allowed to drill holes in the wall, anyway. Just my guess.I don’t see The troubles of wall mounting them to outweigh the benefits.
I won't do it if it’s not worth it I had corner stands but one went missing , they slide in with blades but not exactly as safe as nails ....That, plus you probably aren't allowed to drill holes in the wall, anyway. Just my guess.![]()
@Markoneswift
For example
