You may want to check the DC offset on your receiver/amp. If it is more than a few mv you may have problems with your amp. The speaker protect should have engaged and shut off all sound. if it failed to trip your speakers could get direct voltage and blow fuses and or speakers. You do not want to see the "magic smoke".
Harry
Here are my D3's. Except with Dayton woofs:
How do those sound? I know I should just get the surrounds and do my first refoam (D-3s) but I was curious. What is the model number of those woofers?
looking to get a pair of D-3's free, but according to the guy, they need new foam, worth it??
Googled your fuse and it's a 4amp vs. 2 amp that I blew... I'll start there... Thanks Harry...
Mine read the same as Lee's. They are also rated for 400w's? Thanks for posting this even if it is an older thread
I run 5A 250V fastblo's in mine with zero issues and I put the boots to them daily. I have the woodgrain versions. Bullet horns are gone and a matched set of Heppler Dhorm soft domes now run the highs so the bullet horn shriek at high volumes is no longer an issue. I also added 50lbs of ballast in each and put in cross bracing. Someday I plan to spray the interiors with rhino liner in a can stuff for extra sealing/damping
WTF. Where does this anti- old post crap come from?bumping a 10 year old zombie thread wasn't cool 10 years ago and ain't cool now.. You're not new to forums.
Hey Chris,When I purchased one of the pairs of Cerwin Vega D-9’s I had, the owner had kept everything from the receipt to the sales information that came with it.
I found this again the other day and figured I’d scan it. I don’t know if this information is listed elsewhere or not, but I figured some might find it useful:
This has information for the D-1, D-2, D-3, D-5, D-7, and D-9
Edit: My original scan was lost when I moved from Comcast Residential to Comcast Business and they erased everything I had hosted on the free webspace they gave me... but it is identical to this image.
https://www.hifiengine.com/manual_library/cerwin-vega/digital-series.shtml?destination=node/100984Hey Chris,
Could you dig up that same brochure with the specs please sometime real soon and post the page were it says this ?....
( Helmholtz & Thiel )
...I can't find mine I know I had a couple of the same brochures but they may have been lost in the two moves I've done in my life since 1986
Inside that brochure it talks about the helmholtz and theil design of the D9...
