I'm the original poster and
the picture should be working just fine. I've also edited the post to attach the image directly to the post (this feature was not available back in 2007 when I first made the post).
Also, I'm curious about the origin of your image, as some of the details are different.
For example, the D-9 is 8-ohms nominal, not 4-ohms nominal. The catch is that it has a lower
minimum impedance than most 8-ohm speakers (actual impedance varies depending on frequency and can dip significantly below nominal). This can lead to problems with some amps that people assume won't happen with a speaker that is 8-ohms nominal. Since it was easier than trying to educate people about the concept of minimum impedance, Cerwin-Vega simply began labeling their later models as "4-8 ohms" nominal. From a technical perspective however, they are indeed 8-ohms nominal.
