I think Cerwin rated many of their speakers as 4-8 ohm, to make them sound compatable with every receiver. It bypasses the explanation that you can always go higher with the load (speaker) ohms, and be just fine. You could measure the resistance of the speaker itself and get some idea, impedance is usually about 25% higher than resistance.
As for the comment above regarding hooking up two sets. He may be right, but not necessarily! Some receivers, when using both A and B outputs, internally connect them in series. Usually cheaper ones though. And a quick google of your Sansui, looks NICE!!!!!!! You can tell by hooking up speakers to just A, and switching on both A and B speakers. If they speakers go off, they're wired in series internally.
Looks like your Sansui packs quite a punch! At least 200 a side. And those Vegas are very efficient!! (huge vega fan here) You are going to have one amazing setup!!!!! It'l be loud no doubt!
