The on bulb is where it should , no change
The bulb doesn't screw anywhere , it's pushed with it's black rubber.
How the amp will know if the bulb is where it should ?
It lights , but no relay click...
ON dim bulb or plugged straight into the wall?
Too low of a bulb wattage will fool the amp into thinking the power isn't on.
Then there's the fuses, just handling old fuses can separate age weakened elements.
