Checks \ Steps To Do After Recapping ?
it's HARD to keep track of everything you are doing.
You mean you are taking the preamp out of the sa-8500ii and running it into the spec-4?
The spec-1 has a PROTECTION type relay on the output to suppress the turn on thumps, while the sa08500ii depends upon it's power amplifier's protection relay to suppress the thumps that would go to the speakers. In your set up, you are bypassing this protection with the set up,
SO
The Spec-4 amplifier should be turned on LAST, after everything else has stabilized.
I'm just using the SA8500ii as pre-amp. Recapped it and curios To know how
Does it affect sound eventually.
Tried it and you are right (how surprising ;)
If I turn the SPEC 4 last , it does not occur and it's fine.
Isn't there a way to fix this with the sa8500ii?
I can't imagine someone turns on my system when volume is high on both amps and the big thump happens :(
the only thing i can imagine is some sort of time delay on the spec-4 amp power cord - I have seen things where after the power is on, it takes several seconds to allow power to pass through. Then the amp is automatically NOT turned on, until everything is stable.
I have seen such modules used in air conditioners, power has to be on for a certain amount of time, before the outlet becomes live.
Anything else would involve modifications to the sa-8500ii internally :nono: to allow the protect circuit to suppress preamp output.
