Checks \ Steps To Do After Recapping ?
Aye Aye . Doing this with DBT within 1 minute .
DBT is on.
Bulb is dim.
Red probe on 33 , Black on 36 = 200V
Note : I placed my tester screwdriver on the fuse , the bulb in the tester screwdriver lit up a bit
ok, switch your meter to VDC, ground the black lead to chassis, red lead to pin 47, then 48, then 57, then 58 and record voltages. These are your B+ and B- voltages. Pin 47 and pin 58 should be + voltage while other 2 read - voltage.
47 - 39.2 +
48 - 39.2 -
57 - 39.3 -
58 - 39.4 +
You were right.
checked on the pins , and the soldering also of the diodes that i replaced.
Now check Cathode side of D13, this runs to base of Q8 (+ 25vdc)
Then Anode side of D14, this runs to base of Q9 (- 25vdc)
Then collector and emitter of Q8 as well as Q9
Q8 (C) +26.5vdc (E) +24.4vdc
Q9 (C) -26.5vdc (E) -24.4vdc
The voltage reading will be a little low because of DBT.
q8 - collector (black grounded to chasis) : 39.7 +
q8 - emitter : 0.06
q9 - collector : 39.7 -
q9 - emitter : 01.2 -
Hold on, if they are diodes (they really look like resistors) , I installed them without making sure of polarity. :(
I think they are both installed wrong way . Do you confirm ?
0.0 on 4 points when black probe grounded
I'm starting to believe they (D13+14) are installed wrong way...
q8 - emitter : 0.06
Yep, going wrong direction. Need to pull them and test them both out of circuit.
Pulling them right now...
I also have the old ones BTW...
Sure no problem , thanks friend... If i'm not gonna be here , I am asleep .. it's midnight here in North Israel
Edit
Pulled , Tested using multimeter. No continuity , they give results on 1 direction.
Same results as the old ones more or less.
Soldering them back
OMY GOSH!!! iT clicked!!! WOW .
I can't believe it, 2 tiny small diodes made this mess !
DNPAINTING U R AWESOME!!!!!!!!!!
:thmbsp:
Glad to hear it's out of protection. Glad I could help!
Continue using your DBT checking after each board so at least you will know where the any trouble lies. Make sure capacitors are discharged before hitting them with an iron. Take lots of before and after pics. Be carefull of your pinouts on the transistors, ask questions if not sure. No questions are dumb questions. Check voltages!
Have a good night!
