dnpainting
What size bulb? Also, how dim is it going? Is it still easy to see it glowing?
The lamp/bulb should be at least 100 watts for a spec amp, for any chance of dimming. The higher the wattage the better...
at least 40w, then 60w, but best 100w to start, possibly going up to 150w.
It obviously has to be an incandescent lamp.
The unit worked fine , I just wanted to do recap
There are few transistors that I did not touch .
Everything I replaced I checked and also checked all capacitors I installed
Did not replace the relay
Ok , jampers done , triple checked the capacitors and diodes , checked all Pnp - Npn diodes and all gave me results more than 750
BUT
When I plug the amp to the DBT , and turn it on , the bulb Dims significaly and the amp does not make the relay click
Help!
Tried it , the same
I must confess , that I also hooked the amp directly to electricity .
It did not not do anything , the same silence , no smoke no pop no pfff
Ain't it strange that fuse doesn't get any voltage from neither sides ?
Pull the fuse and check for continuity. Are you checking for AC or DC voltage?
Checked , there is continuity . Fuse ok. Checked both (AC / DC) ground was taken from the amp's ground behind transformers
There is no AC outlet in the back of the amp
