Checks \ Steps To Do After Recapping ?
023 EQ Board
attachment.php
attachment.php
Remember, things are flipped when looking at this compared to the board :yes:
So just to be sure again
This is Q6 in the switch board
The new part number is KSC2383YTA
The writing on the new part facing the inside of the amplifier
Hi Mark , Goodmorning to you there in Illinois :)
I am going over the "three legged diodes" LOL ! PNP/NPN transistors , and found out at least 6 of them in the control amp were wrongly installed.
Deslodered them and mounted correctly according to the info you guys provided me above . Got to ask , can I use the same ones ? is there a chance they are already fried or what..? I can use the old ones if they are fried for sure. or can order and get new ones (will take 1 month)
The one closest (Q6) looks to be correct, the one up by the stacked cap (Q1) looks to be reversed.
attachment.php
omri617,
One thing that may help in the future,(at least it did for noobie me!) was before you remove the original transistor, to mark the board along the flat side of the original transistor with a thin line marker. Then look in the Pioneer service manual for the diagram of the transistor you removed and compare it to the diagram in the spec sheet of the replacement transistor and the markings on the board. My cheap Harbor Freight multimeter's transistor tester verifies the lead arrangements further. (You only get a HFE reading when it's plugged in correctly) Once you have the board back together and working, a little isopropyl alcohol on a cotton swab will remove the markings from the board.
Hope this hint helps!
P.S.
Not sure if you have a "Harbor Freight" in Israel, but this is the meter I use:
http://www.harborfreight.com/ac-dc-digital-multimeter-37772.html
Read that link on how to test them before you re-install them in case some did get fried.
Got into the one you told me it was wrong in the switch amp
Fixed it :
Made a progress , but also a bit of a mess (next relpy- can't add more than 1 photo)
To post more than 1 pic at a time, the pictures have to have different names. All the images you have put up say "image". Add a 1, 2 etc., then you can post multiples in one post
Well all diodes are how they are supposed to be now , but there are 10 diodes.
Ksa992fbu - 6
Ksc1845fta - 4
I'm so confused here , don't know which ones go where (the schematic looks not so clear , can't locate them there - Can't find foil view of the control amp & eq. amp)
If you are looking at foil view, things are reversed. If foil view shows that transistor at right side, the location is actually on left side of board. It's like taking the board with switches pointed at you, looking down on top at all the components, then spinning it over, keeping the switches still pointing at you, if that makes sense to you.
By the way , checked the resistors according to EchoWars guide and Mark's testing :
first the PNP:
black lead to base, red lead to collector, result = 675
black lead to base, red lead to emitter, result = 688
red lead to base, black lead to collector, result = OL = No conduction
red lead to base, black lead to emitter, result = OL = No conduction
black lead to emitter, red lead to collector, result = OL = No conduction
red lead to emitter, black lead to collector, result = OL = No conduction
next the NPN:
black lead to base, red lead to collector, result = OL = No conduction
black lead to base, red lead to emitter, result = OL = No conduction
red lead to base, black lead to collector, result = 677
red lead to base, black lead to emitter, result = 680
Did on all 10, all gave me results above 750, so I guess it's a good to go.
Found a better Service Manual than the one I was using , recommend it for the people who will need this in the future.
II service manual (en) - jaguarondi
http://www.hifiengine.com/library/pioneer/sa-8500.shtml
Ksa992fbu - 6
Ksc1845fta - 4
Are you saying that your not even sure if you installed the correct replacement in the correct location? Just trying to verify things is all.
Only remove 1 Transistor and then reinstall Correctly (if that is the correct replacement part) before you remove any others.
I sent u 2 emails containing the entire SM and other containing link to download it, just incase one or the other doesn't work.
Installed all diodes the way they should
Now the boards look like this :
More of switch
Also , had a visual check on all parts I could look at , and saw this disturbing thing :
Pre in / out
