Chocolate records
wouldn't this be horrible for the stylus? Even if you did it just once, I think you would get a bit of residue on the needle
I can't imagine it'd be tooo bad on the stylus. After all, chocolate is pretty soft, and it'd kinda melt as the stylus went through it. As long as you clean it off afterward...
I think you'd use a special stylus made out of dark chocolate or baker's chocolate to run through it though.
And don't forget to clean the CLPs with chocolate milk.
I can't imagine it'd be tooo bad on the stylus. After all, chocolate is pretty soft...
Well, I caught a chunk of the Mythbusters marathon today and one episode was on being deserted on an island and needing to start a fire. Apparently, chocolate is abrasive and can be used to polish/grind the bottom of a soda can to create a reflective lens which can be used to start a fire. Who knew?
