Fab9
Member
I really like this formula too, because it’s very similar to the one recommended by jBL. What ratio do you use between linseed oil and limonene? 1:1? 3:1?Photos will be great to see.
I like lemon and boiled linseed oils.
I have never used steel wool on speaker cabinets, but it works well on wood and metal. I vacuum and use a magnet to pick up the shredded pieces.I'm looking for the old material for the maintenance of wooden houses, and this is what I found (l65 user manual).
It seems that using steel wool is recommended by JBL, but it's an operation I won't be performing.
other JBL user manual:
Hard to tell with photos but I'd guess Walnut. Your speaker cabinets look to be in pretty nice shape.thank you for advice.
Which color do you reccommend for my L65? walnut? dark walnut?
Here we go,
some photos of my L65.
The defects are present exclusively on this case, the other one is in better condtion.
Hi, I looked at the ebay ad you linked to.@markd51
Your tips are really helpful, thank you!
Is it better to use felt or buy a 2mm foam pad, like the ones on sale on eBay? what do you think?
Foam Pads for Top of JBL L55 & L65 Jubal Speakers - 1 Pair | eBay
Le migliori offerte per Foam Pads for Top of JBL L55 & L65 Jubal Speakers - 1 Pair sono su eBay ✓ Confronta prezzi e caratteristiche di prodotti nuovi e usati ✓ Molti articoli con consegna gratis!www.ebay.it
The same foam can be found on Aliexpress for a few buks.
I just checked all the screws, they are in order, even the ones on the woofer, thanks for the advice.
Yeah, the foam is the best choice. Available at craft stores, too, if you find their pieces large enough not to have to splice.@markd51
Thanks again for your suggestions and your time. Your messages are very useful to guide me in the restoration work.
I ordered some 2mm foam sheets, I hope the thickness is right, I will cut them to the right size and insert the JBL logo in the correct position.
