markd51
Nyuk Nyuk
A little hard to tell, but it does look like the glass does sit a bit too high.
It started ~1mm proud but settled flush.A little hard to tell, but it does look like the glass does sit a bit too high.
Nevermind - I just looked again. It's still a little proud of the wood!!It started ~1mm proud but settled flush.
I used Krylon Color Maxx flat black spray paint.In some spots on the front, the matte black paint has chipped off. Wich paint do you recommend?
Thank you
Hi, for that amount of minor damage, the last thing I'd be reaching for is a can of spray paint.Hello everybody,
Just an update:
I cleaned the L65 with water and degreaser and with water and alcohol.
I bought a product for restoring walnut furniture and pure wax.
I'm waiting for the boiled linseed oil and gum turpentine and then I will decide wich one to use.
Some doubt about black paint:
Thank you
You know I have a couple of cans of spray paint. I spray a little onto a cardboard or small glass container and brush it on.Hi, for that amount of minor damage, the last thing I'd be reaching for is a can of spray paint.
Not unless you're willing to carefully mask everything else on the speaker, and only leave these tiny areas exposed.
Wouldn't it be easier to use a small artist's brush, and carefully dab these areas with a product that came in a small bottle? You'd be done in a matter of a few minute's time.
Yes, that too can probably workYou know I have a couple of cans of spray paint. I spray a little onto a piece of cardboard and brush it on.
It works. Really.![]()
I can vouch for it. I only have spray cans.Yes, that too can probably work
Here's something interesting.I've used sharpie markers for that kind of stuff
Bronze wool is the way to go. Non magnetic and doesn't rust.I have never used steel wool on speaker cabinets, but it works well on wood and metal. I vacuum and use a magnet to pick up the shredded pieces.
If you can flush the sanded object with water or solvent also helps clear the metal debris.
I will get my calipers and measure...
As for the cut size of the sheet, does it fit correctly? Not sure, but you speak of compression.
Maybe this foam could be attached to the original existing Paper Card Stock?
