Lou G
FWIW, when I first made the change from a set of Zu Audio Mission speaker cables to a pair of fairly high-end Synergistic Research biwire cables, I did notice a difference but but didn’t feel that the improvement justified the expenditure I had made. It wasn’t until I picked up a set of the corresponding ICs from the same guy that I found out what the new cables really sounded like.
Your experiment was done with some pretty good components and I have zero interest in getting mired in yet another cable debate, but you don’t mention the ICs used. Had you installed some pretty good ICs first and then performed your test, the results may well have been different. You can put the best speaker cables on the planet in there, but they’re still the last link. All they can do is show you what the rest of the system upstream sounds like, be it excellent or not so much.
For the test that I posted in #742, all the music was from lossless ripped CDs on a Music Server. A friend of mine purchased the Morrow speaker cables and found no difference between his older cables and the Morrows and asked me if I wanted to try them. His system is the Peachtree Nova 300 with Wharfedale Evo 4.3 speakers. The Peachtree is an integrated amp with a built in DAC so no interconnects were used in this case. The other 3 systems are my systems where I used my DACs as preamps feeding the amps directly. The 3 DACs used were a Benchmark DAC1, a Mytek Stereo192-DSD and an Emotiva XDA-2. All the interconnects between the DAC/preamps and amps were Mogami 2549. I always felt that the Mogami were pretty good interconnects.
