mhardy6647
Lunatic Member
... point (no pun intended) being?
A few posters have mentioned conical needles of the .6 mil size. If .7 is considered standard for stereo LPs and later Mono records, why isn't .6 a bit of a misfit for those grooves?
Or does the .6 mil conical tend to ride the grooves where there is less wear or offer some other beneficial property?
I have worried, perhaps mistakenly, that a .6 mil stylus would collect up debris in the bottom of the groove that other needles don't encounter.
I'm old enough to remember when the NEW stereo records had warnings on them not to play them with needles for mono LPs. That was when the earlier mono microgroove records were meant to be played with the 1 mil needles. (Of course, only a very few years later, the mono LPs were being cut in the narrower groove.) Of course, you could play those wider-grooved early mono records with the .7 mil stereo needle, so that is an example of a needle .3 mil smaller than recommended being considered acceptable. In that light, going from a .7 mil down to .6 or even .5 mil to play stereo grooves doesn't sound that weird.
The conical that I use the most is a Shure SC35C with original U.S. made .6 mil stylus (of which I have about a dozen NOS) tracking at 4.5 grams in an Empire 398 turntable. I also use a M3D with a Jico N3 stylus (purchased directly from Jico) and for lighter tone-arms, a Shure M35X. All of which are very smooth sounding cartridges. I also have 2 rare NOS Shure N91GD (U.S. made NUDE .6 mil) styli that don’t get much use because they are impossible to find.
I’ll take a good quality conical over a run of the mill so called “elliptical” any day. The reason for this is that most of the “ellipticals” available are simply conicals with the leading and trailing edges ground flat to approximate an elliptical shape. This is done partially for marketing purposes and partially to reduce tip mass. The record groove still sees a conical profile.
Have you used the Audio Technica AT-DS3 ? :scratch2:
I have seen it in use, but have no personal experience.
http://www.lpgear.com/product/ATCDS3.html
https://www.audio-technica.co.jp/atj/show_model.php?modelId=525
