You say you are running the sub from speaker B terminals and a set of speakers from the speaker A terminal. My question is: Does your sub also have its own set of speaker outs? All subs I have seen have both speaker inputs and speaker outputs. If you run the wire into the speaker inputs on the sub, you might want to run another set of speakers on the subs output. That may be where your impedance mismatch comes from. I have a powered sub that is connected to my Yamaha CR-2040. Either speaker B or C, cant remember which, but I also have two small speakers run off the subs speaker output. Can listen at any volume level for any amount of time with no problems. Remember, since it is a high level input, the sub is getting ALL frequencies so it has to have a crossover inside to split up those frequencies so the sub can get the lows. It then sends the rest of the frequencies out the speaker outputs. Since you have nothing attached there, the sub may sense an impedance mismatch and shut down. Just a thought.
