Get you a good ole Bunn. They are around $100. Mine was still working fine after 14 years. Gave it to a friend of mine to get one of these.
http://www.webstaurantstore.com/ava...h-1-upper-and-1-lower-warmer-120v/177C10.html
It is great too.
Some interesting products here, although none of them fit the bill for me right now. To put it in audio terms, I'm not on the market for the Krell of coffee makers, more like a NAD.If anybody has any suggestions for a drip brew machine with a timer, in the ~$100 or less range, I'd like to read them.
+1, I bought a Bunn back when they were $50
Its over 20 years old. I picked up other at yard sales.
The ONLY issue I've ever had is that the seal on top of the tank is now getting old. A little rubber gasket engineering fixes that.
Last I saw at Target, they are now $80 or so.
They have hot water ready. Put the grounds in and pour in the water and a pot of coffee is ready almost as fast as you can visit the bathroom. With a little skill (and if you are awake enough) you can fill your cup and slip the pot in when you pull the cup.
Yeah, nothing fancy. US Folgers types LOVE it!
I had one of those; it only lasted a couple of years. I still use the carafe for the coffee I make in my still-working, much older Braun.![]()
There isn't anything below $150 that will brew in the correct temperature range..
Same failure with a Krups Made In Germany unit I had. Fortunately didn't set fire to anything though.I had a Braun Aromat 10 some 20 odd years ago. The thermal cutout failed and it set fire to my kitchen counter. Last time a Braun appliance ever found its way into my house.
There isn't anything below $150 that will brew in the correct temperature range...
What is your correct temperature range?
I have a $30 Cuisinart on-off switch no timer nuthin' fancy model, it puts out 195°F water into the coffee. Measured it with a digital thermometer. It uses #4 Melita filters which I prefer. Makes great coffee.
I have one of the cuisinart ones with the grinder built in, the idea of sleeping through a coffee grinder in the morning is odd but my family does fine LOL.
That thing cranks out some HOT water, burn your face off hot. It also has a setting for 1-3 cups where it really cranks the heat so they are brewed properly. I am watching this thread because it seems to be taking a dive and acting goofy.
Evan
Cuisinart coffee makers have notoriously short lifespans. Just how hot was that water? Most Cuisinarts,if not all, don't make it up to the necessary 192-205F range.
I can check, now I am curious. Interesting on the short life span. My water is very hard though, and I assume that takes a toll as well.
197.6-204.8F (92-96C). It's not MY range, it's the Specialty Coffee Association of America's range and those folks really know their stuff. Their water requirements make interesting reading. I have to cut my tap water 50/50 with distilled to get close.
At my altitude (4950') I can use water as soon as it stops actively boiling. That's very convenient. Don't do that at sea level.
https://www.scaa.org/?page=cert2
Site needs a little updating: the Lance Larkin BE 112 Brew Express is no longer made.
Cuisinart coffee makers have notoriously short lifespans...
I've never heard that. What are your sources for this statement?
