Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
The move to the new server is done. There are some software and database maintenance updates in process. This has us passing the hat around to help out. We appreciate any donations. Seriously, even a dollar helps. The payment page may be found here - https://www.audiokarma.org/support.html
Those are Telefunkens. Definitely not Valvo, Siemens, or any of the other West German manufacturers. Wow. And more wow. I bet they'd sound great in my 1958 Fisher mono console.
dude, rebuild that little amp and enjoy. you've got great tubes and the makings of a decent little SE amp. you'll need to recap it and bypass the power switch leads that run to the tuner section at bare minimum.
Is there a website or something that offers a description of how to rebuilt it? I assume the first step would be to find a schematic. What would you guys do after that?
This is the website. Type "Magnavox 196" in the search box and read to your hearts desire. Also, be sure to read the stickies at the top of the tube forum. I'm sure someone will be around very soon that has a schematic for it.
First: You want to replace the coupling capacitors, electrolytics (if the amplifier hums) and then you'll need to add binding posts for the speaker outs and maybe change some other circuitry around. You will need to add a power switch as well.
Tools you'll need:
Multimeter
Soldering iron
Solder
Wire cutters
Needle nose pliers
Basic Electrical knowledge
you can work without a schematic if youre careful and replace one part at a time. take quite a few well focused closeup pics of the underside of the amp so you have something to look back at if you get lost. you will need to replace the electrolytic filter cap and any wax-paper coupling caps it may have. you will also need to rewire the power leads going into the amp to bypass the molex plug.
have you worked on tube gear before? its not too hard but there are very high voltages in there with when its plugged in.
Google "Telefunken EL84" or even search fleabay, that will give you an idea. You won't really screw anything up unless you drop the tubes and break them Then they're toast.
Thanks for the Schematic. Which Caps would I need to change? Just the 2 I circled or is there more? Any suggestions on which caps to get and which power switch and speaker connectors to get? Any other suggestions? I have not done much with electronics and have never worked on tube amps. What kind of preamps do people use with these amps?
Trying to identify the maker and year model of heirloom console pictured here. Fully operational, all manuals and even the punchcard, right down to the wipecloth. This was the only post featuring matching information. What the heck do we have? And I wonder how rare and/or collectoble these are? There isn't a brand name, tag or indicator as to manufacturer, the manual is as lacking in branding. ???
Sure looks like a magnavox to me. Try posting a photo in a new thread and welcome to AK.
Might be a paper label on the back panel with all the relevant info, model number etc...
OP hasn't posted here for a very long tim so don't expect a reply from them.
Welcome to AK. The amps mentioned earlier are Magnavox and the schematic is a couple posts up. Post a new thread with some pics and you'll probably get more info.
I believe there are only minor differences between the 196 series and the 197 series. It's a single-ended amp with a pair of 6BQ5 output tubes and a single 12AX7 input tube. I have one but I forget the exact model number. A very nice amp that puts out roughly 5 wpc.
