Thats a problem...Do you have a 1N4148 on hand?
D718 is showing 4.75v on not banded side and 20.3 on banded
Shows 156.2 ohmsWith the unit powered off what is the resistance between the collector of TR702 and chassis ground? Looking for around 165Ω relay coil resistance.
Close enough..Shows 156.2 ohms
I see 4.74v on each sideR748 47Ω 1/4 watt ?
good..I see 4.74v on each side
See initial post ;PWhat voltages on TR706?
Replace it.-- TR706 that is. KSC1845 will do.See initial post ;P
Swapped for an 1845, no change.Replace it.-- TR706 that is. KSC1845 will do.
Do you have a replacement for 2SB544? TR702..
KSA1013Y
Give it a shot..Don't have any 1013s on hand, would a BD140-16 work? Looks overrated but not incompatible.
Give it a shot..
Check for cracked solder,traces or broken solder pads. around TR706,TR702 area.It's just weird that when I tap the base of tr-706 with the red probe of my multimeter, with black grounded, the relay closes immediately.
Check for cracked solder,traces or broken solder pads. around TR706.
Snacking? Cheetos?snacking it
Snacking? Cheetos?
Ohm out the traces in the protect circuitry..![]()
Yes. But ....Is there a better quality board scan,
