Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
The move to the new server is done. There are some software and database maintenance updates in process. This has us passing the hat around to help out. We appreciate any donations. Seriously, even a dollar helps. The payment page may be found here - https://www.audiokarma.org/support.html
Check the collector voltages of the 4 output transistors. Should be around +/- 49vdc. +B and -B can be measured carefully** on the output transistor's metal cases.
**----- Don't short the metal cases to the heatsink --- You will regret it.
Preamp power supply +/-25 rail now both ok after TR714 fix?
Try setting coupler off and connecting a iphone (or whatever) at minimum volume to the main-in then slowly crank up the vol on the iphone...
the coupler was extremely oxidized for some reason a little contact cleaner snd deoxit and everything is right in the world. Now i just gotta wait on this left channel amp card to come in and it should be all good.
