hifitommy
it's my belief that what is needed is the clamping of the record to the surface of the platter (short of having vacuum hold down/clamp or a clamp and periphery ring) the less weight,the better. i have a planamax (french and no longer available) that is nearly weightless and l like it a lot.
i used a ratshack plastic clamp that reduced the ringing of the platter on my kd500 tt, of COURSE they stopped making it just as they did the excellent decca type record brush (like an AQ bur with finer and consequently more carbon fibers. i still use that.
i also have the sota reflex clamp which i like the best but can collide with certain carts like the v15Vxmr due to its large diameter and thickness. i also have an ORSONIC DISC STABILIZER DS-250 that is also a reflex type but smaller and slightly less effective on warped discs.
integral screw down clamps that come with some tables like the VPIs i find to be excellent and are usually lightweight the way i like them.
the astronomically priced clamps/weights made of exotic materials and bizarre mechanics will be for others that are amenable to the cost vs performance ratio of such.
