komoyuki
Hi Komoyuki,
Fantastic looking room. Before trying to sort out the acoustics, I suggest you set up your speakers in nearfield monitoring position as per the picture below to take the room basically out of the equation.
This will let you hear what you should be aiming for and if possible aim for the mid field monitoring position I describe in the rest of the thread here:
http://grantfidelity.com/wordpress/audio-tips-and-tweaks/setup-your-existing-system-first/
This should dramatically reduce the amount of acoustic treatment you will need in your room.
Cheers,
Ian
Ian I know this blog probably by heart and effectively I had this link in my favorites. On the other hand, to keep the speakers 4 feet from the front of the wall is a little bit unrealistic, I am going to try to move them forward as much as possible but to keep them in a practicable proportion. I am moreover going to have the opportunity this weekend to make really of the positioning and verify what would be the best location.
Wow, it looks really nice ... !!
Can I ask for some more room pictures - maybe with some more lighting?
Its a bit dark and I could really appreciate all the gear and textures
if you had some lamps behind you to throw more light around the room.
My TV room is darkened when we are using it,
but I do have extra lights turned on when I take pictures.
Be without fear I am going to post several other photos a little later. Let us say after my yesterday, I began to have my day in the body. Sorry not to work rather fast!
The room looks great! I'm interested in knowing why you switched from the RITA to the W-30.
-Steven
I never have possessed RITA amp. Maybe that you confuse with Jungson JA88D which I had. Grant Fidelity takes their case to make their RITA, but he takes that of the JA99D.
Phil.
