Hey all, hope I am posting this in the right place.
We've all had our fair share of speaker and amp mishaps I'm sure, but I'm trying to make sense of something that happened the other night.
I have a pair of Aerial Acoustic LR5 speakers. I had been driving them with a pair of mono blocked Crown PSA-2XH's. Which put me at around 900-1000 or so watts I believe per amp into 8 ohms. I needed the amps to be powerful and 2 ohm stable, as the speakers often dip below 2 ohms at louder volumes.
I had my eyes set on a Macrotech forever, finally two popped up owned by a church.
After watching them blow both up by powering them into a 240vac outlet when they were wired for standard 120 in front of me
, one is now repaired.
I hooked everything up, have my computer hooked up to a DAC, balanced XLR outs into the PIP modules in the back of the Crown, and I mounted that bad boy in the other room as it is loud as heck. I am only using one, I absolutely do not need two.
I started rocking out - probably two or three hours went by until I noticed a burning smell, then I lost my midrange or a tweeter.
Powered everything off and opened up the crossovers to find the 10 watt emitters on one speaker XO looked as if it had melted out of it's solder joint and shorted across another joint.
Now I thought this was isolated to the one speaker but curiosity got the best of me and I opened up the other one to check it out as well. Sure enough, the same emitters were just burnt up, one was split in half but still testing okay, othervalues had changed (by an ohm or two, nothing crazy).
This whole ordeal also damaged my tweeter and I had order a replacement.
I admit I like listening to things LOUD, I'm a drummer. But I do my best to not push my system past it's limits and any hint of distortion at high volumes scares me so I am not afraid to back up that volume control quickly.
Here's where I'm thinking I messed up. The whole time I was just thinking things sounded too... harsh, too compressed - especially compared to the warmth I liked on the PSA-2s in the low end.
I had the input sensitivity set to the default 26db gain, and my balanced output delivers somewhere between 1.2-1.4v I believe. I guess the 26db gain sensitivity has a fixed sensitivity of 4.8 volts?
This was obviously my issue right?
The replacement tweeter came in today, I have adjusted the sensitivity to 1.4v and the harshness I experienced originally is COMPLETELY gone, I am very very happy with the amp now, my only concern is this happening again.
Thoughts anybody?
Thanks!
Thoughts anybody?
Thanks!
