CS350 vs XR27 center, RonC?
McSpectre
Member
Which is a better center, with LS360 speakers?
The CS350 center seems voiced the same as LS line, and is non fatiguing. (Own it and happy)
But I hear the XR27 is much better from resellers!
Opinions.
Thanks.
XR27 will have more bass as it is bigge, has more woofers and a larger midrange. If you are crossing over at 80 Hz the two will be similar in response but the XR27 will play louder.
Thanks,
Ron-C
Thanks,
Ron-C
Being I cross with 2 JL113's at 80hz with the CS350 would the XR27 be a big improvement with sound quality or just play louder as stated above.
Mine seems loud enough now...
I think you had this LS, CS combo Ron at one time.
If it will be a huge dynamic change, then its a move I need to make.
As most of the HT sound comes from the center speaker.
If it is going to throw off the LS synergy for 5.1 music, I will pass.
If you judge the CS350 to be loud enough I would say you are set to go.
Thanks,
Ron-C
