oh wow. i didnt realize that. with that short a warranty, theyre counting on premature failure.Yes, they were Apex matched. They stand behind what they sell but not a month down the road.
damn. AES offers those “apex matched” JJ tubes. thats too bad what a hassle.
funny thing there; its usually psvane failing and JJ, as long as its not a 5AR4, performing without malfunction or failure.
oh man.I've seen at least half a dozen shorted JJ EL34 or KT88 tubes do serious damage to amplifiers too, over the years. I also think they sound very good when they are working.
interesting.And people based in Europe seem to report better luck with them.
man, that has me wondering if AES or APEX is getting discards.My Croft preamp came with a set of 5 JJ ECC83S labeled Edicron, and they're among the best 12AX7 I've had, but the ones i bought from AES were terrible - not meeting spec plus they had hum from the filament.
Some JJ octal output tubes are notorious for having thinner-diameter pins. If your sockets are loose and a bit worn, these thin-pinned tubes can lose their bias voltage and go ballistic.I had a bunch of JJ tubes go bad recently. 3 or 4 of the 6CA7's went red plate over a year, with very little use.
These tubes even drew too much current on the tube tester. They were definitely bad.Some JJ octal output tubes are notorious for having thinner-diameter pins. If your sockets are loose and a bit worn, these thin-pinned tubes can lose their bias voltage and go ballistic.
Also, I've had issues with Chinese-made ceramic sockets. Their contacts are sometimes made of fragile gold-plated metal. These can also lose contact with the tube's pins due to thermal expansion and vibration.I never use these sockets anymore.
if those are dissipation values, it doesn't really translate to power output. Unless you're applying more voltage or current to take advantage of that at least. Similar to plugging a 6L6GC in place of a 6L6G. Its still doing 6L6G power in a 6L6G amp. You can however design an amp around the 6L6GC to make use of it's limits.ve read somewhere that the Tesla E34L may have been rated at a maximum of 30 watts, compared to the EL34's 25 watts
IIRC the guitar guys were talking about biasing them hotterif those are dissipation values, it doesn't really translate to power output. Unless you're applying more voltage or current to take advantage of that at least. Similar to plugging a 6L6GC in place of a 6L6G. Its still doing 6L6G power in a 6L6G amp. You can however design an amp around the 6L6GC to make use of it's limits.
that blue and red glass is so cool lookin. the old arcturus are gorgeous.I remember biasing them about 10% hotter. Provided the unit could take it.
I really liked the sound of the E34L, throughout the early 1990s, JJ versions. I have not tried any new issues since 2010.
Red glass ones were sexy!![]()
From my experience, they are hardy tubes! Vintage Tesla's E34L is second only to the Xf2 Mullards among Marshall head amp users, in terms of sound and reliability.Looking at the JJ data, it seems the E34L requires a little less negative bias voltage for the same current, indicating higher transconductance than the EL34. It makes me a bit afraid to try it, because the normal version is already prone to failure. I can't see raising the transconductance while holding all other variables the same as a move that would improve reliability.
That is fun. Once. Clean up is a real PITA. If you don't have to clean up, have me over, I will bring a pile to wreck.
From my ex
I have no idea about the reliability of the current JJ E34L.![]()
The St Petersburg Svetlana EL34, too. I wish they still made those.I remember those 1990s Tesla tubes. That was when it was either those, NOS Siemens, the Sovtek EL34G, or the Chinese tubes. One thing I miss about that era, is that an eastern euro or Chinese EL34 was a $10 tube - it was an entirely different matter to have failures when the tubes were cheap.
10 in 1992 is about 23 bucks in 2025 so the price really hasn't moved. New JJ are about 25 each.
svetlana didnt get sold.No kidding! It was such a shame when Svetlana got sold.
