Is that the same as "compacted"?Someone sent me a couple of 5755s with adapters to try. I endured a weekend of pain to see if they would get better. One word to describe the sound — "constipated."
I sent them back.
I sent them back.
Although I don't do vinyl, the operating point of a tube used for RIAA or whatever EQ curve you want, will have a tremendous influence on the "sound" of that tube in a phono stage circuit. Input loading and output impedance will also influence the final sound.I tried 5751 in a phono stage of something once, thought it sounded awful. I have absolutely no idea what became of those tubes, they are here somewhere but no idea where. I'd actually like to try them in something to see if the slightly lower gain is any advantage but I'm not quite curious enough to want to pay money for the experiment.
I've never tried different tube types than what a phono preamp came with myself. It would effect the EQ curve for sure. If a phono stage is designed to use say a 12AY7, using sonething else wouldn't be an improvement. Most MM cartridges use a 47K loading. So at leased there's kind of a standard there. There's also the capacitance of the cables. Some cartridges sound better at 200pf, others at 100pf, etc. It's easy to get lost in the weeds with phono interconnects. I've always just used the length the turntable came with and called it good.Although I don't do vinyl, the operating point of a tube used for RIAA or whatever EQ curve you want, will have a tremendous influence on the "sound" of that tube in a phono stage circuit. Input loading and output impedance will also influence the final sound.
I have yet to try out the quad of Westinghouse 6CA7 tubes that were gifted to me. Anyone have any experience with the Westinghouse branded ones?
Yes. Prolly Shuguang EL34s.Those to me look like early 1990s Chinese made EL34s. Around that time, Westinghouse was distributing whatever they could get their hands on. I bought some of their 12AX7 tubes in 1991, and they were Ei Yugoslavian tubes.
And in my experience, even different makes of 12AX7s can sound very different in phono and input stages. More than changing brands in the second gain and phase inverter stages. Very unit dependent. It comes down to trial and error.Although I don't do vinyl, the operating point of a tube used for RIAA or whatever EQ curve you want, will have a tremendous influence on the "sound" of that tube in a phono stage circuit. Input loading and output impedance will also influence the final sound.
Any experience / thoughts on how they sound?Yes. Prolly Shuguang EL34s.![]()
Rich midrange, some say a dark sound. Bias them on the cooler side, if possible. I've heard they may go ballistic if they're are biased too hot. Buying them from a dealer that tests and burns them in is kinda nice.Any experience / thoughts on how they sound?
those are definitely not westinghouse.I have yet to try out the quad of Westinghouse 6CA7 tubes that were gifted to me. Anyone have any experience with the Westinghouse branded ones?
They can be the best sounding EL34s. Buying from a reputable dealer that tests, culls out the bad ones, and burns them in is half the battle. Chinese tube manufacturers' QA (even with the boutique brands) can be iffy.Very good, but they could be prone to reliability issues. Back then they were also sold as premium tubes by a company in the UK called PM Components, under the Golden Dragon name.
In my experience, Chinese output tubes need more burn-in time than equivalent Russian-made ones.
Yes, I'm not sure Westinghouse ever made 6CA7/EL34 in their US or Canadian plants. The "Westies" I've seen are relabeled European Philips, Ei, or RFT-made.those are definitely not westinghouse.
I've found that to be true with several tube phono preamps I've had and have.And in my experience, even different makes of 12AX7s can sound very different in phono and input stages. More than changing brands in the second gain and phase inverter stages. Very unit dependent. It comes down to trial and error.
Thanks for the updates regarding the "Westinghouse" 6CA7's I posted. Given the tube sets I have I am really in no rush to try them, but I will eventually.
What happened with the EF86? That’s the only number I’ve ever seen for that tube.In the 20th century, there was a trade organization called the Radio Manufacturer's associstion (RMA) which standardized the naming of tubes in the USA. A company would invent a new tube, and the RMA would issue a name for this tube. The first number is the heater voltage, the letter(s) are a sequential identity given to a specific type tube, and the last number, is the number of "elements" in that tube.
The Europeans had their own separate system which had a letter for heater voltage followed by more letters to designate the type of tube, and then a number to indicate the sequential identity.
Imported tubes that were imported and sold in the USA in any quantity would get registered under an RMA type number, in addition to their original European tag. The 6CA7 type number was introduced in the 1950s, when the Dutch Philips EL34 tube was imported and distibuted by Amperex and the UK EL34 Mullard as well. The Japanese also adopted the 6CA7 designation around this time. These are all pentodes.
The true American beam power 6CA7 came well after 6CA7 tube designation was registered and commonly used, when the US companies developed a domestic alternative to the imported tube. It seems that it has retroactively become known that the beam power tube is a 6CA7, and pentode is EL34 but in reality, both versions of the tube were originally 6CA7 and EL34, and to determine the actual construction of a specific 6CA7 or EL34 tube, it should be examined instead of solely relying on the name.
IIRC, the Ei 6922 was the tube that Roger Modjeski loved and bought in bulk.Ei tubes seem to prove you right. Nobody wanted them when they were made, and suddenly the NOS ones are worth money!
great…online asking prices for 807 are climbing now
6267What happened with the EF86? That’s the only number I’ve ever seen for that tube.
