Even in U.S. made gear where the U.S. codes are stamped on the chassis, or both U.S. and European codes are listed, I don’t recall seeing anything other that EF86 marked for that tube. I’m assuming it didn’t get a regular consumer RMA code?6267
westinghouse us did not.Yes, I'm not sure Westinghouse ever made 6CA7/EL34 in their US or Canadian plants. The "Westies" I've seen are relabeled European Philips, Ei, or RFT-made.
From what I remember, the Tesla E34L is rated at a higher output than the EL34, too. They have quite a powerful sound, kinda like the vintage Xf2 Mullards.You can get NOS blue Tesla E34L tubes from an eBay seller that's UK based for a similar price too (make an offer), but they don't offer matching services. The E34L is an industrial spec'd EL34 if I remember correctly?
I'm planning on trying them with some RFT ECC865, which are an industrial version of ECC85, which also have a slightly higher output, would this translate to any extra watts? Amp is a Luxkit A3500, in UL configuration.From what I remember, the Tesla E34L is rated at a higher output than the EL34, too. They have quite a powerful sound, kinda like the vintage Xf2 Mullards.
well, switching the letters like that is european special quality variant.You can get NOS blue Tesla E34L tubes from an eBay seller that's UK based for a similar price too (make an offer), but they don't offer matching services. The E34L is an industrial spec'd EL34 if I remember correctly?
I've read somewhere that the Tesla E34L may have been rated at a maximum of 30 watts, compared to the EL34's 25 watts (push-pull, Class AB1). Really, the system will not be that much louder, but the tone and audio response will be different with the E34L. More powerful, same strong mids, but maybe a bit darker.I'm planning on trying them with some RFT ECC865, which are an industrial version of ECC85, which also have a slightly higher output, would this translate to any extra watts? Amp is a Luxkit A3500, in UL configuration.
You'll soon find out!Is it worth getting a tester to match them? I brought 6 in the hopes that 4 of them will be close enough, or is that too optimistic?![]()
It depends on where you bought the tubes from... If from a third arty that measures and pre-screens the tubes, then you should be fine. If you bought the tubes from Amazon or direct from the company, then very likely the tubes will not match closely. As mentioned before, Chinese tube measurements are never what the company claims. Unfortunately, some Chinese tubes are only available direct from the company or Amazon, such as the Psvane Summit tubes, which not available from tube resellers.Is it worth getting a tester to match them? I brought 6 in the hopes that 4 of them will be close enough, or is that too optimistic?![]()
I had a bunch of JJ tubes go bad recently. I won't use them anymore. I rebuilt a couple of Marantz tube amps for a customer. 3 or 4 of the 6CA7's went red plate over a year, with very little use. Unfortunately the customer went to Florida and by the time he got back and started to use the amps the tubes were out of warranty. I had 6L6's go redplate, 6V6's and one 12AX7 doa that the supplier replaced. All JJ.Does anyone here have any strong feelings about JJ vs EH 6CA7's? Are there any other true 6CA7 options currently out there? I see some PSVANE around but they are frosted so I can't see the construction.
I'm considering trying out a set of new tubes to rotate with the old-stocks, but it's a significant investment with 2 matched quads needed for my Quicksilvers. Original Sylvania 6CA7s are consistently my favorite power tube in any amp that's compatible, and luckily they last pretty long by all accounts.
Good luck!![]()
oh no. from where/whom did u buy em?I had a bunch of JJ tubes go bad recently. I won't use them anymore. I rebuilt a couple of Marantz tube amps for a customer. 3 or 4 of the 6CA7's went red plate over a year, with very little use. Unfortunately the customer went to Florida and by the time he got back and started to use the amps the tubes were out of warranty. I had 6L6's go redplate, 6V6's and one 12AX7 doa that the supplier replaced. All JJ.
www.tubesandmore.com. The 6CA7's and 6L6's were matched sets so they were tested. I also had EL84's from JJ go redplate. I have switched to Mullard, Electroharmonics, and Tungsol and had no issues with them. A customer had me use Psvanne and no issues with them either, but they are pricey so I don't use them unless the customer requests them.oh no. from where/whom did u buy em?
damn. AES offers those “apex matched” JJ tubes. thats too bad what a hassle.www.tubesandmore.com. The 6CA7's and 6L6's were matched sets so they were tested. I also had EL84's from JJ go redplate. I have switched to Mullard, Electroharmonics, and Tungsol and had no issues with them. A customer had me use Psvanne and no issues with them either, but they are pricey so I don't use them unless the customer requests them.
Yes, they were Apex matched. They stand behind what they sell but not a month down the road.damn. AES offers those “apex matched” JJ tubes. thats too bad what a hassle.
