Dali 4a speakers
vonclod
Anyone here ever have a set? from Denmark and 93db, I cannot find any type of review.
The 93db part is good:thmbsp:
Sold by mail order in the US. One of the woofers is not original in your picture. Utilized Vifa drivers and real wood veneer. Still have my 2's.
Edit: My bad, the drivers are original. I was unaware of the difference between the 4 and 4a. Dali has the brochures for their older speakers online.
Cool, thanx for the info, so little info out there. From the pics out there on the net I do believe they are the correct drivers..I did find out that they are 4ohm which id rather not use in my low watt amp.
Cheers
Ok thanx, I couldnt find much..I will take a boo again.
Thanx
I have a pair. Your drivers are original. They are like that two drivers of different shapes. And most importantly and strangely those drivers are simply wired in parallel. First order crossover if I remember correctly. Use Bennic polypropylene caps for the Vifa D26TG-05 1" Tweeter.
They are most suited for driven my T-Amps and other low power Class-D amps, that like 4Ohm loads...
