It is hard to accept things that challenge our beliefs.
True words.
I will continue to acknowledge my observations, and Crown's.
http://www.crownaudio.com/pdf/amps/damping_factor.pdf
True words.
I don't suppose there is any vested interest in Crown's promotion of extremely high DF vs. what seems to be an independent assessment?
But I agree totally with crown's doc....with the addition of how mechanical properties of the speaker may affect the results....
Not unless you are suggesting that I am comparing the size of my "thing"....
jk
.....the Guy who built/assembled my speakers and made the crossovers from scratch, said to me one time, "a higher damping-factor has more control of the voice-coils"....I don't know, but my MC2105 with a damping-factor of 10, renders tube-like performance from the speakers....is tube-like performance from solid-state equated with a note being allowed to sweetly ring longer?....
.....aren't QSC amps actually Crowns?....
Well, I'm also an EE, but I find the Crown article interesting, but troubling. I find their explanations incomplete.
Now, they do a good job explaining "ringing" and how damping should control this "unwanted" cone motion.
Electrical damping, however, is NOT the only way to control cone movement as jk reminds us in his post. "mechanical" methods also come into play. For example, the trapped air in an acoustic suspension system can create enormous drag on a large cone.
Regards,
Jerry
.....WhoArU, I don't know why, but I thought Crown had something to do with QSC amps....I know there's a lot of happy QSC owners.....
syn⋅er⋅gy /ˈsɪnərdʒi/ Show Spelled Pronunciation [sin-er-jee] Show IPA Pronunciation –noun, plural -gies.
1. combined action or functioning; synergism.
.....Ehoove, do you mean the synergy created by the correct combination of components and speakers is what brings the tube-like/life-like performance?.....
They further talk about back EMF and how it helps control the ringing; that is, by being 180 degrees out of phase and being feed back into the amp.
What's incomplete is they assume the back EMF gets to the amp unattenuated. They completely ignore the LP coil in series with the woofers that is fairly high impedance (at least compared to speaker cables).
Now look, if we have a motor (ringing voice coil) and we want to damp it (slow it down), the way to do that would be to "load it" (i.e. have a very, very low resistance). This is E Science 101.
Well that coil is anything but a low resistance and allows the motor to "ring" and to dissipate energy fairly unencumbered. That coil will also change the phase relationship as the signal that "gets to the amp" will no longer be exactly 180 degrees out of phase.
Only when the coil is removed (as in powered subs or active bi-amp), will the amp ever experience the back EMF. Now, in all fairness to Crown they sold a number of professional amps where speakers are driven strictly in "active" mode. Sooo, maybe for their business their explanation is accurate. I don't know.
Regards,
Jerry
i have a kenwood amp that touts a 10,000 damping factor
