Hi There,
I just completed these mods last night and am now listening to the BS-22s with a nexus 7 tablet as a source playing FLAC files, a YJ Audio three tube pre--6z4 rectifier with upgraded military 5670 tubes in lieu of 2 6n3s, and a modified tpa3116 Danzz-designed YJ black/blue amp (coilcraft inductors, Wima MKP10 input caps, Ceramic bootstrap caps, etc.)
I really liked these speakers before the mods, got them from Amazon with the59$ sale, plus I had a $50 gift card from X-Mas so with shipping I had a grand total of $13.50 into the Pioneers.
Prior to these, I was using a set of Dayton B652s for my near field listening on my desk that also had a new crossover in them courtesy of Dennis Murphy (and his design there really made those better.)
But, while they may lack a little bass compared to the b-652s (with their 6.5" woofers) the Pioneers in stock form were certainly better than the Daytons.
So, I was very excited when Dennis Murphy announced he had a mod for the Pioneers and I was even more excited when he emailed me the specs and BOM and schematics.
Then, I found this thread and thanks to MCM Fan, I had a complete and easy to follow set of instructions for the work.
So, I ordered up the parts and busted out the iron and got to work.
Unfortunately, when I completed the mods I could not get the speakers to work. My 3116 went into protection mode every time I turned the volume up. I thought perhaps it was an amp issue and a big coincidence so I hooked the modded speakers up to my Sansui B2101 in my HT set up and fired them up there. No protection, but the speakers sounded tinny and soft and I realized that the woofers were not putting out any sound--or barely any sound.
So, it seems I failed.
I double checked the instructions, double checked the connections, couldn't get them to work.
Tested all the drivers, they all worked without the crossover (and again, the tweeters were fine) so I guess I screwed up the boards or something with all the desoldering, resoldering, ungluing, etc.
To fix the issues, I decided to ditch the original pcb altogether and just run that part of the crossover circuitry point-to-point.
Laid out the circuit on some board, twisted the ends together, glued them down, soldered it, reconnected my new board piggybacked to the radio shack perf board (connected with the same lead from the added woofer inductor on that board), re-assembled, fired them up on the Sansui B2101 and, SUCCESS!
From what I can tell, I must have messed up the original PCB when I made the mods. But, it seemed weird to me that BOTH speakers would have the same fault when the circuits were separate. I think I may have damaged the pad where the added inductor makes the connection from the radio shack board to the original pcb and thus had the short.
When you connect the two boards you have to solder the inductor to the original pcb pad and screw them together with the spacer to the terminal cup. I solder it then tightened it up to the terminals and when I did that I think the torque ripped that pad off both of the original pcbs. Not totally sure but I think that is what happened.
I think that if you don't have a high level of DIY skill like MCM Fan and others on this board it may just be easier to remove all the parts from the original crossover board and point to point them yourself. Maybe buy 4 of the radio shack boards and just use that to set it up, or use perf board, foam core, whatever you have laying around. Would cost a few more bucks, but at least then you are sure everything is good with the connections and pads and such.
Or, maybe I just needed to take my time and be a little more careful. It's hard to get all that old glue off the original crossover board, remove the parts, get it clean, etc. MCM Fan's diy guide is so sano, so clean, and mine looked like crap by the time I was done hacking away at it.
Other than that, the only other issue I had with the instructions was in the foam measurements. I am 99% sure I measured the pieces exactly for the sides--6.5 x 4.5 and mine were too short and I had to add two @.5" x 4.5" pieces to fill the space all the way along the bottom of the cabinet.
The rest of it worked like a dream.
--EXCEPT for the fact that when I opened my Vifa tweeters from PE to install them I found that one of them had a completely pressed-in dome! Luckily I remembered reading about the toilet paper and mouth suction trick on line and was able to suck out the dimples and such and restore it to "new" form. I didn't want to wait for a replacement from PE. Not sure what happened there, the driver was wrapped and packed perfectly when I opened it.
But I digress.
Once I fired up the modded BS-22s they performed as advertised. Much better high end, way more integrated sound, better soundstage, etc. All those details are there and more. the little breathing noises, the quiet hi-hat hits. I had noticed before that when it was loud and the bass high, it sounded a bit strained, some break up or something. I think the installed foam handles that nicely. I keep going back and forth on whether I want a sub under the desk but I just don't see the point. I have Kraftwerk "Kardiogram" on right now from Tour de France and the bass is great. Tight, focused, can feel it in my chest.
In short, they are as greatly improved by the Dennis Murphy crossover as my B-652s had been, but because the B2-22s in stock form were already better, the mods really took them up another level.
Cash out of my pocket is now like $95 for these, which is about what the mods to the b652s along with the original speakers cost.
So, for the same money, there's no real comparison.
These things are great.
As always, thanks to everyone for sharing your skills and expertise. Thanks MCM fan for all the work on the guide, and thanks to Dennis Murphy for being so nice and always sharing the schematics and specs for these tweaks.
And, if you don't have time or inclination to mod these things yourself, I would just by a set from Dennis Murphy. He's basically giving them away. Totally worth it for what he is charging.
