$100Please provide your budget.
It's probably just that there are so few things to recommend (new under $100 is a very limited category nowadays) so other than the 4 or so carts mentioned above, there really isn't much else to discuss.I'm a little surprised at the low responses.
I took a look but it's actually a $50 difference. Still worth it?AT-VM95EN is worth the extra $20 over the E
They are both elliptical and feature the same radius, so you're not really going to hear a HUGE night and day audio difference between the bonded and nude versions. Otherwise they are essentially the same. If your budget is truly $100, you won't be missing much going with the E vs the EN. Some *claim* the EN might track a little better, but it's hard to really quantify that.I took a look but it's actually a $50 difference. Still worth it?
Well, you had asked about the Denon 23F in particular, a turntable that I've never used, and maybe one many here have no experience with.I'm a little surprised at the low responses.
Well, that's quite a list. The cartridge is going on a table that is about 1400 miles from me, it's my son's and his wife has expressed an interest in playing some LPsWell, you had asked about the Denon 23F in particular, a turntable that I've never used, and maybe one many here have no experience with.
The current production cartridges under $100 I could find are:
AT-VM95C
AT-VM95E
Sumiko Oyster
Sumiko Black Pearl
Grado Black3
Goldring E1 (possibly just a temporary price reduction to $99)
Ortofon OM 5S
Ortofon OM 5E
Ortofon Super OM 5E
Ortofon 2M Red
Rega Carbon
Music Hall Melody
I've owned six of those and had some audition time with two others. The most satisfying to me is the Sumiko Oyster, but while it sounded great on a Rega RP3 and AT-LP120XUSB, it did not fare so well on a Denon DP-300F. If I were buying a cartridge for that turntable, I'd be inclined to go with a Rega Carbon, but this is just my best guess. For a few years, I would likely try a different cartridge each time I wore out a stylus, just to see what different options sound like.
it's interesting...which carts you are not recommending for this turntable?You cannot just use any 1/2 inch cart because there is a very fine height tolerance with this table - arm height is not adjustable.
