Beavs
Easy enough, thank you. However, few questions:
Where do you know to pull the voltage (2V above) off of the schematic? (I'd like to learn stuff like this so as not to ask the same type of question again)
I must have had the PDF cutting off part of the part description on these when I looked earlier. The BOM lists R551,553 as: 100 ohm, +/-5%, 1/4W, Carbon (NBS). R559 is the same specs but (NBF).
- Any idea what NBF vs NBS is? Physically they look the same except the R551 and R553 are oriented vertical off the board and R559 is horizontal.
- All are axial resistors. Can I just order axial across the board and bend the leads to orient vertically on R551 and R553?
Finally, the schematic BOM lists Carbon for these, whereas other resistors list as Metal Oxide Film. Still good with ordering Metal Film mentioned above?
