So, an update.
I deliberately only replaced one set of op-amps previously, IC501 (in the idle current section), it seemed best to to not replace IC502 at the same time if I wanted to be able to hear any potential differences.
The amps have been sounding great so far. And in the meantime I have been doing some thinking about op-amp choices.
Using the OPA1656 in the IC501 position seems like a bit of an overkill, with it's 100mA of output current being wasted there. However, the M5218 in IC505 has 50mA of output current, and the 1656 is the only part that I have on hand that meets or exceeds that. And the OPA1642 nearly matches the idle current draw of the original NJM082 parts while still having a bit more output current.
So I soldered up a pair of OPA1642 parts to try out in IC501, with the plan to move the OPA1656 to IC502.
I made that swap today.
Before putting the amps back in the rack I checked voltages. The supply voltage rails to the op-amps did not change, remaining at +/-15.1v. The idle current voltages did not change with the new op-amps, remaining at 8mv with a slow fluctuation of about +/-0.2mV. The DC offset was 6mv left amp and 2mv right amp before the swap, with a fluctuation of about +/-0.2mV. This remained the same after the swap.
My expectations were that I did not expect any change to speak of. My expectations were wrong.
My immediate impressions after one CD (all that I have listened to so far) is that the highs are improved, vocals are clearer and more understandable, and there is more depth to the soundstage.
Now that I have posted this I am going to go back and spin some more disks and explore this change.
James
