So this last Monday I went back to it, removed TR502/503
again, and repaired/reinforced most of the traces connecting 502/503 to the surrounding parts using the snipped off tinned copper leads from some caps that we always save. I realized today that I only took one photo of that, on my cell phone. So I will retrieve that and post it. As an example of what not to put oneself into a position of needing to do. I am certainly not proud of it.
Anyway, after doing that I was back to seeing exactly the voltages that I was getting in late April. Then got an intestinal bug and fever for Tuesday and Wednesday. Got back to the amp on Thursday, and finally, way late, the (very) Dim Bulb on my shoulders brightened up a bit and I did what I failed to do in April and checked the rail voltages in the output section.
And found zero volts on the +80v line. This was easily traced back to... ...wait for it... ...F002.
A 10A 125V fuse.
That I should have checked 2 months ago.
Which caused me to do a bunch of useless flailing around that did nothing but waste time and cause damage. You might note that I am a bit upset with myself at the moment.
James
