That's annoying...Seems at the end of my projects theres always a couple fine thread mystery screws while the majority are course thread. UghThere is an odd mix of machine screws and sheet metal screws
I have a theory the inner plate forming tosses around the C value on old & new caps. In other words I rarely test them, lol.There are 2 caps that I replaced on the PSU board, C003, 004, 470µF/100v. The old caps measured about 460µF.
They were replaced with United ChemiCon KYA 470µF/100, the new ones actually measured high at 513µF.
View attachment 3174794View attachment 3174795
Cheers,
James
Enter...the amp chicletsLast step with the power supply board was to add some Panasonic ECW 0.01µF poly film caps in parallel with the main filter caps and re-solder the rest of the connections.
View attachment 3174938View attachment 3174939
Cheers,
James
I have yet to have 2 working amps to try out.Enter...the amp chiclets
Since ya have more than one of those amps, have ya compared one with bypass caps & one without?
,I do usually test all old parts. you can get a bit of an idea of of how many hours it had. The A-1020 for instance. A lot of caps in it were cooked to have their rated value. Both of these Denons look very pristine inside and out, the caps all test at or near nominal and the solder connections look nice. I get the feeling that they are low hour units.I have a theory the inner plate forming tosses around the C value on old & new caps. In other words I rarely test them, lol.
,I'm right there with ya on power supply health brotha.But on the other hand, I am a firm believer that anything that can be done to clean up the power supply pays off through the entire device.
I've had a good experience with power supply bypass caps in tuners. Haven't tried it in amps yet.It's one of those things that probably can't make a hearable difference all by itself, but at the same time can't hurt.
First time for me in an amp. I did a lot of stuff with CD players in that regard. Bypass caps on the filters, ultra fast soft recovery diodes, heat sinks on voltage regulators and stuff.I'm right there with ya on power supply health brotha.
, I lied a little. Didn't wanna shat on your efforts. I tried bypass caps once in the secondary mains in a Yammie M-60. Pulled em right back out after setting it up in the living room.First time for me in an amp. I did a lot of stuff with CD players in that regard. Bypass caps on the filters, ultra fast soft recovery diodes, heat sinks on voltage regulators and stuff.
James
Do you happen to recall if the bypass caps were polarized per chance?They will have bypass caps on those main filters
You and all of my other AK Pals are officially allowed to shat on my efforts.I lied a little. Didn't wanna shat on your efforts. I tried bypass caps once in the secondary mains in a Yammie M-60. Pulled em right back out after setting it up in the living room.
,0.1µF and 0.01µF film caps, NP by nature.Do you happen to recall if the bypass caps were polarized per chance?
Yep, Wima, eat your heart out.Enter...the amp chiclets
Lol...well said sir. I might have had a better experience placing the bypass caps across the main filter caps vice the secondaries. Sounded great on the bench. Put it all together and then it sounded foul in the living room. I'm kinda modification shy ever since.You and all of my other AK Pals are officially allowed to shat on my efforts.
In the immortal words of Robert Heinlein "This is Liberty Hall. You can spit on the mat and call the cat a bastard".
James
Wish the Z man would chime in more. Hint hint. Always thought he was cool on past threads.Yep, Wima, eat your heart out.
Not all ECW are the same. Some have tinned steel leads and some have tinned copper leads. Fellow AK Pal zaibatsu and I looked into that a couple of years ago and so far have identified 8 or 9 that have copper leads, going from 4.7µF on down to 0.01µF
