Didn't get a lot done today, re-soldered and re-capped the front board.
Caps.
I continue to believe that these first 2 amps are low hour units. The caps in the first amp were nearly all near nominal and so far this one also. Nonetheless, as with the other one all elcos except for the main filter caps will be replaced.
Rant Mode ON: The Great Cap Swindle just pisses me off more and more. It is a crapshoot if what we buy is at the stated value or not. In this regard Panasonic FC, FM and FR seem to be better than some other brands and especially FM are near nominal more often than not. Rant Mode OFF.
C102: 1000µF/35v. I bought 2 different FC for this position, 35v and 50v. The 35v all tested between 965µF and 970µF. The 50v tested even lower at an average of 945µF. This value isn't available in FM or FR. I used the 35v part.
I'm wishing now that I had ordered some UCC KYB 1200µF/50v for that position. They probably would have tested at around 1080µF.
https://www.mouser.de/ProductDetail/Chemi-Con/EKYB500ELL122MK40S?qs=IYueExuAvkp/sidVSI1iLQ==
C103: 0.47µF/50v. Used a Wima 63v part.
C104: 100µF/35v. Panasonic FM 50v.
C105: 1µF/50v. Wima in 63v.
C107: 33µF/16v. Panasonic FM 35v.
C108: 220µF/63v. Panasonic FM 220µF/10v.
C110: 100µF/6.3v. Panasonic FM 10v.
C111: 10µF/16v. Wima 50v.
C112: 10µF/50v. Wima 50v.
C113: 47µF/35v. Panasonic FC 50v.
C120: 22µF/16v. Panasonic FC 35v.
For C113 and 120 I had FC, FM and FR, the FC tested nominal so I used them.
Zener diodes. I had no luck finding a nominal value replacement for D113 and D123. I broke my rule and re-installed them.
D105: HZ15-2, nominal value 14.8v. Used 1N965B. Bought 100 and it was easy to sort them and find a 14.8v part.
D110: HZ5C-1, nominal value 5V. Used a MTZJ5V1SB.
D113: HZ7B-3, nominal value 7.15v. Original part tested at 7.12v. Re-installed.
D123: HZ9B-2, nominal value 8.7v. Original part tested at 8.65v. Re-installed.
For the rest of the board I only re-soldered the parts and did not remove anything.
Then the board was cleaned and re-installed. After that I pulled the input switching board, that will get worked tomorrow.
Cheers,
James
edit: btw, R131 was re-positioned a bit after the photo was made so that it is not pressing up against that 10µF Wima. I don't know how hot it might get.
