Here are some 8 Track pics as requested by relmasri
Thanks for that Derek.
The tape path is very similiar to that of the compact cassette players and yet the 8 track cartridges look very different to the compact cassettes, amazing!!!
Easy to get parts if they breakdown?
Rabe
They run on an endless loop with the tape coming from the center of the reel which is angled, and is taken up but the outer part of the reel as the reel spins, the tape passes over the heads 4 times per whole album play with the head moving 4 times to change between the 4 stereo tracks. I have never had to buy parts for them, although sometimes pressure pads and splicing tape is required to fix. The only thing I have done is change the plastic type rollers over to the rubber type rollers for better tape grip (got these from tapes I did not play much and swapped). They have a bad habit of jamming on the splice/joiner due to their age, also tension can be an issue depending on how they have been treated/stored. The sound could be a lot better, but this comes down to the machine and how well the tape was recorded by the factory. There are plenty of 8 tracks on ebay last time I looked, which can be used for parts.
I am relieved to hear that you can still get parts to maintain the unit because, from what you are describing, the cartridge goes through a bit more of the tape transport than the compact cassette in order to get the sound, thus requiring more maitnenance ...
Rabe
I think its also a higher tape speed, the machines tend to get dirty much faster due to the age of the tape too. The main thing is to keep the capstan drive clean inside the machine, because if the tape wraps around this it is catastrophic. This was common in cars when people would leave the 8 track inserted whilst the car was parked in the heat, therefore making the rubber roller on the 8 track soft and sometimes sticky. When the unit is powered up again the tape wraps around the capstan and can destroy it. If the tape gets pulled out for any reason you need to take it apart and wind it back manually which can be difficult. Also if the joiner breaks the tape can spill into the machine and pull entirely out of the cartridge, I've seen this happen on home players. Then again some 8 track cartridges never have this problem in their entire life span without a problem.
I need to try some different 8 track machines because I think I can get better sound from these cartridges. Lots of them have lived in cars most of their life and the heat/vibration has gotten to them. That 8-track machine I own could also be worn. Alignment is usually an issue because it is never perfect between the tracks and cross talk is common, you can sometimes hear part of the other track quietly during quiet passages of the track you are playing. There is quite a bit of information crammed into the tape, very close together.
many people just don't appreciate tape anymore, its actually a very strong format which will outlast the dye layer on cds (and possibly dvd's). If looked after well they really do last, having high end machine(s) brings out the best in them every time.
Thanks for the nice comment :thmbsp:
Mp3 Sounds like a tape deck that is out of alignment and has dirty heads, in other words "under water".
A Nakamichi BX-1 Cassette deck, sounds beautiful after a full service. Kenwood KX-3510 HXPRO Auto reverse deck.![]()
