Ok, this is a QUICK and dirty test, so i didn't take a lot of time.
First test... distortion
01 ok
02 breaks up (distorts) a little bit with the final brass horns at 1:04-1:05. ***Yuck*** Rejected. IS THIS THE GRADO?
03 slightly cleaner than the rest on trumpet although very slightly distorts on the final brass
04 ok
05 ok
06 ok
07 distorts very slightly in trumpet break and final brass, or it's my imagination?
08 ok
09 distorts slightly in trumpet break
Second test... tonality
01 brightest of all carts, slightly lean on bass
02 more bass, less midrange,
03 ok, highs more defined, bass ok
04 slight emphasis on the presence range, more treble but smooth.
05 similar to 03 and 04
06 midrange is forward
07 more or less similar to 06, midrange forward, treble subdued
08 midrange even more forward than 07
09 ok, highs defined, similar to 03 but with more bass
3,4,5 are similar
6,7 similar
...although it's jumping into conclusions.
All cartridges sound OK on tonality except #1. I like the forward midrange of #08, although on a room it might not be so good (i'm using headphones).
Now for a REALLY marked difference... Using audacity...
Third test: Resonant frequency of the tonearm+cartridge...
For me this is VERY important since in my experience (and science seems to agree), the more controlled is this resonance, the more "stable" the sound since the warp regions (2-9Hz) are intermodulating less with the audible frequencies.
01 8Hz -6dB OK
02 9Hz -1dB Poor
03 8Hz -1dB Poor
04 8Hz -9dB good
05 7Hz -12dB very good
06 6Hz -7dB. 6Hz is not a good frequency.
07 13Hz -16dB !! EXCELLENT -- THE WINNER
08 8Hz -9dB OK
09 11Hz -13dB !! almost excellent!
Jumping to conclusions
For me, tonality is not so important, but i'd discard #1 unless we can tame the brightness with loading.
Number #2 is discarded because it breaks up at high levels on the brass section at the end. I like classical music and this thing won't perform well with fortissimos, i'm afraid. I hope this one of the Grado cartridges.
That leaves us the resonance frequency criteria, which is highly important to me. On this criteria the best performers are:
07 13Hz -16dB !! perfect, amazing
04 8Hz -9dB good
So all in all i'd immediately choose #7 or #9, without a blink of an eye. But #5 and #4 are also fine choices.
In all fairness, all cartridges are satisfying performers.
