From someone who did this professionally for a LOT of years.... There is no 'easy' way to transfer vinyl to digital that will sound good (or 'clean'). I still use a variety of programs, depending on the task at hand. I have yet to see one program that 'does it all', let alone does it 'easily'. The first 'hint' I can give you is this however: if you start with a clean record it makes your job a LOT easier. The second hint is to 'practice' - play around with a program for a while until you try to make a CD or anything. But it takes a LOT of time and experience to do it 'right'. But once you've figured it out it goes pretty quickly. I can usually scan and clean the cover digitally while it is played, and finish the audio within an hour of transfer (all cleaned, tracks split, fades, ect.). That all comes with familiarity with your programs and what you want/need to do. One more hint: I've found better programs made by people like the folks that are on here than the larger, well known programs - and for a lot cheaper too.
