infullview
It shouldn't as long as you don't have any plastic parts attached to it. You can also control the heat by wrapping a wet rag around the shaft just above the section to be heated.Will that mess anything up if I do that?
Second opinions on this idea anyone? I know this works on autos, but I have never tried this on a turntable bearing. In theory it should work though.Will that mess anything up if I do that?
Okay, looking at his photos (which I should have done, first) ---- isn't the cap holding the bearing screwed into the shaft? Or lightly pressed on? I would think it shouldn't require heat to remove.Here is a picture of the spindle, and bearing well cap with thrust pad. Notice the flat spot on the spindle, is that normal? @ripblade I have replaced all of them.
View attachment 1657108 View attachment 1657109 View attachment 1657110
I'll take a closer look when I get home tonight. Thats what I was wondering though, something has to unscrew somewhere I would think..Almost looks like it should unscrew where the clip slot is. If you shine a light in the slot, can you tell if the slot was machined or can you see any evidence of fine screw threads?
I purchased it back in June I think, prior to that I have no idea how it was treated. When I bought it it was spinning too fast, like excess of 100 rpms, thats what the tech fixed.How many years does this turntable have on its odometer? I'd suspect improper previous installation of that bearing surface face, maybe a big issue. You may need to find another one of those, if possible. Or risk prematurely wearing out a new bearing.
I think the very end is a retaining cap that was applied with heat. I'd bet if it was heated up a bit and pushed with popsicle stick right where the clip ring goes, it would slide off. Just a guess of course, but I don't think it would hurt anything to try it.I wonder if they didn't swage the end of the shaft down just a wee bit to retain the bearing ball to make assembly easier. If thats the case, heating it might expand things enough to drop the bearing out. If the material files, I'd be tempted to stick it in the lathe and just face the very end of that off to release the bearing, and then just leave it as a pocket for a ball to sit in.
Nice turntable! Kinda rare, though. I couldn't even find a "donor" used one (for parts), on the Net.@Mr Boochie Sanyo TP 1000, I have looked high and low for a service manual, replacement parts, information, etc with no luck. I saw a couple posts on vinylengine where someone was aksing about the bearing about six years ago, it never received a response though.
