RayW
So with a rooms longest dimension say 25ft the frequency when
nodes would appear should be approximately 90hz and the magnitude
mitigated by room absorption or in the context of this discussion DB.
An iphone using the built in microphone is mostly useless below 200Hz. It won't help much with setting up subwoofers. PE has a mic that plugs into the headphone port that is rated down to 18Hz and is pretty inexpensive.
http://www.parts-express.com/pe/showdetl.cfm?partnumber=390-810
RayW
You went the wrong direction. Like Dave said, you'd be looking at ~23Hz. A 25' wavelength corresponds to about 45Hz. Doubling the wavelength would correspond to half that. That's about where you would get into pressurizing the room.
Anyone want to guess what the graphs are showing?
I'm going to guess blue is without the subs, purple is two, and red is three.:scratch2:
