I would have to reconfigure the current wiring but it would be doable as the Aretha MKII does have two outputs. Currently have a SS preamp feeding the SS power amp and a tube preamp feeding the tube power amp.Can you bi-amp them with the ss on the woof and EL34 on the CDs?
Cool! I have drivers for Open Baffle full range speakers. At this point I’m just going to use plywood sheets for quick design iterations to find the best sounding layout.
I wouldn't think so? The coil is insulated from that screw and is mounted on wood. Running a screw theough a Toroidal transformer can cause problems and even damage if the mounting screw isn't isolated from the metal chassis and or coil.Looks nice, but don't you think that the screw and washer would have at least some impact on the air core inductor? You could use a brass screw/washer.
The rough openings were routered with a chamfer bit to eliminate any 90 degree angles.
Take an hollow core induction coil, put it on an induction meter. Pass a screwdriver through the center and watch the meter.I wouldn't think so? The coil is insulated from that screw and is mounted on wood. Running a screw theough a Toroidal transformer can cause problems and even damage if the mounting screw isn't isolated from the metal chassis and or coil.
When using a cover especially. A plastic or rubber insert and washer to isolate the screw from the windings are used. Sometimes a plastic screw and nut is used as well.
Could you say a bit more about the "cone"? Just curious about it. Did you buy a kit from La Dolce with the cone included? I suppose it puts some acoustic load on the woofer. I heard these speaker at the last Pacific Audiofest in Seattle. I really liked them. The kit price seems very reasonable too.Bass reflex cone installed before the 18 inch driver is mounted.
