True about spherical tips being insensitive to VTA/SRA re tracing, however another factor is the angle relationship of the groove vs generator armature motion in the cart that best reproduces the motion of the cutter stylus for minimum error. This means that, depending on the system, an audible change may indeed be audible changing the angle with a ball-point tip. The standard starting point for all 1/2" mount carts generally is the top plane of the cart (not necessarily the arm or headshell, depending) parallel with the surface plane of the record. Twiddle VTA from that point once you've established the level reference point index on the Techie MkII's VTA dial for that cart in that headshell on that mat.
